跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
2011 iMac no backlight- Logic board?
Hi all,
I have a mid 2011 21.5" iMac and there is no backlight on the LCD. If I shine a torch on the screen I can see all the icons faintly. I can see also see everything on an external monitor clearly.
I thought the issue might be with the LED Backlight driver board so I replaced that and no difference, I can still only see the icons faintly with a torch.
I then tried another LCD and same result. Icons only visible faintly under a torch.
Now I'm starting to wonder, is it a faulty logic board? I read this post here Mac: Signs of a Bad Logic Board (scroll down to Display and Graphics Problems) It's also not the GPU hence as I mentioned the I can see everything on an external monitor.
Does this look like a logic board issue? Everything I've done is leading me to this conclusion.
P.S. All the diagnostic indicator lights go including the LCD communication one. So the iMac is detecting the screen.
Please let me know if you have some advise.
Cheers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
The Techwalla article is very top level and generic.
A laptop internal display often uses one cable connection and one logic board so everything is on it.
In a desktop (iMac) the display being larger requires much more power to light up the larger LCD panels backlights and the cables are independent between the power and display signal cables. In this iMac the backlight logic is held within an independent assembly as well (LED backlight driver)
You are on the right path the backlight is the issue not the main logic board.
完成的
Hi @danj. I tested it with a Ohm meter and I got 10v going into the LED backlight driver on all 3 drivers I have. I also got voltage coming out of the cable that connects to the backlight driver.
I have tried everything. I put a new power supply in from an identical model, 3 different backlight drivers and now after reading what I saw in the link leaves me to believe it’s the logic board.
What are your thoughts?
完成的
I think you'll need to find the schematics to see for your self. The issue is still the Power supply to LED driver and then the display its self. Something is just not right here the voltage you measured is low it should be 12 volts and 24 volts if I remember correctly.
It sounds like you have a second system is that correct?
完成的
@danj Yes that’s correct I do have another system of the same model. The bizarre thing though is that I swapped the power supply’s, from the working one to the not working one and it didn’t even turn on! All I got was the one LED! So you think the voltage is wrong?
完成的
Post some really good pictures of your logic board with your QUESTION. that way we can see what you see. Post some extra ones from around the DP connectors 在已经存在的问题里加入图片
What voltage do you have on L9000?
完成的
添加一条评论
2个答案
最有帮助的答案
The backlight driver board still could be bad its also possible the power feed from the power supply to it is not working correctly either because its cable has an issue or the power supply its self is bad.
You’ll need to probe the circuit checking the voltage from the power supply and the LED driver board to see if the power is getting to it and then check the two cables coming from it to the display making sure they too are not damaged and are working correctly. I would test them with the system not powered to start with, checking continuity with an Ohm meter, then testing for voltage.
这个答案有帮助吗?
得分 1
1条评论:
Hi @danj I tested the connections and I was getting 10V. I also tested it on my working mac of the same model and got 12v. What does this mean? Cheers
完成的
添加一条评论
On the Mac that the backlight isn’t working on I got 10v. On the working one I got 12v. Can someone please check and let me know what the right voltage is ASAP? Cheers
这个答案有帮助吗?
得分 0
1条评论:
Where are you measuring?
完成的
添加一条评论
添加你的答案
Jacob Milly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 299
