跳转到主内容
加入维修社区 - 创建账户
Screen doesnt work after battery replacement
After I replaced the battery of my ipod nano 3 the only display like a white color.
Everytime I reset it, it makes two beeps after starting. I tried resetting via iTunes, the iPod itself and getting into the diagnostics mode. I can hear the iPod making click sounds when I use the buttons. I checked the display ribbon cable multiple times and made sure it is properly stuck in there.
I afraid I fried my screen because I can´t disconnect the battery before connecting the screen since it is soldered on. Do I need a new screen or is a connectiong loose?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I rechecked the the display connection and made sure it properly sits in there but what do these two beeps mean? Also could I have fried the display because I connected it while the battery was connected? It was working fine before.
由完成的
添加一条评论
1个答案
最有帮助的答案
Philipp Udwari  the white screen means that our backlight is on but no video signal. You do need to check the connector and make sure that the cable is straight and properly seated. If all of that works out, the next step would be a replacement display.
这个答案有帮助吗?
得分 1
2条评论:
由完成的
I got the same issue. Could you solve it?
由完成的
添加一条评论
添加你的答案
Philipp Udwari 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 24
总计 777
