跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
Backlight of iPhone 4 is dim after submersion
I took my iPhone in a lake a while ago, put it in rice, and tried to turn it on. It didn't work, so I ordered a battery from here, and it started working again. The only problem was the LCD backscreen was very very dim. I'm wondering how I can fix this problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Okay, my iPhone was submerged about a month ago. It wouldn't turn on at all and I put it in rice for about a week, and still no luck. So, I bought a new battery for the iPhone and replaced it. Luckily, the iPhone turned on, and I could see that the iPhone was up and running, but the screen was EXTREMELY dim. I had to use a light source (the beams coming off it) to FAINTLY see what was on the screen, but it was on!
完成的
添加一条评论
2个答案
已选择的解决方案
Before you do anything else please follow the ifixit water damage guide.
Electronics Water Damage
这个答案有帮助吗?
得分 3
1条评论:
完成的
添加一条评论
Put the phone's logicboard in IPA, this removes any corrosion and may even fix this
If that dosen't fix it, you will need a LCD/digitizer assembly
The backlight is in the screen, there is also a small chip that shorts sometimes and will need to be replaced, so look for a burnt or shorted chip under the shields, in fact, remove them for the IPA cleaning
Want more info?
http://forum.gsmhosting.com/vbb/archive/...
这个答案有帮助吗?
得分 0
10条评论:
Nick please take more than 1 minute to read and answer a question. You probably would give better answers that way.
完成的
is the backlight part of the lcd or is is a separate coil like on the 3gs?
完成的
good job on the editing
完成的
i thought so..was just trying to get nick to give a more thorough answer
完成的
Oh I see like mentoring the little grasshopper...:-) sorry for butting in....;-)
完成的
显示更多的5条评论
添加一条评论
添加你的答案
chadderbox25 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 3,391
