跳转到主内容
加入维修社区 - 创建账户
iView SupraPad 776TPCII 是一款 7 英寸触摸屏安卓平板电脑。
charging USB port bent
How do I open my tablet and fix the pins in the charging port? It will only work if I wiggle, put pressure on and hold a particular USB charger in a perfect place & that changes every time. Pls respond I have no idea what I’m doing. Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@iiwilltry use these guides iView-776TPCII to at least get you into the tablet and remove the motherboard. The USB port is solder to the motherboard. This will require you to desolder it. Then you will have to find a proper replacement. You can try and scour ebay or Amazon for one or check places like mouser.com or digikey.com after you measure your USB port. Once you have a replacement you will have to solder it to the motherboard. If you have never done soldering on a circuit board I recommend you practice on some old boards first.
这个答案有帮助吗?
得分 3
2条评论:
Thanks for your answer-But I'm not going to be able to do this-Can't I just open the tablet and gently bend the pins back in place?
由完成的
for that you would not have to open it. You can try and bend them back in place and hope they do not break and that it will work. You will have to use something non-metallic to try Usually there is wear and tear on the connector that causes this issue.
由完成的
添加一条评论
添加你的答案
Red 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 419
