跳转到主内容
Repair guides and support for 17" laptops in the Pavilion Notebook 17 series. These laptops have model numbers 17-g000 – 17-g099.
16 个问题 查看全部
Laptop doesn’t boot makes clicking sound and then repeats
Laptop makes a click or spark sound around the CMOS battery area
17 inch HP Pavilion with i5 4th gen processor
Recently replaced my HDD to an SSD and when I went to test out the SSD I accidentally picked up the laptop to turn it around and forgot about the rechargeable battery which immediately turned off the computer.
I tried rebooting the computer again and it just turns on all lights with fan running and then few seconds later turns off and hearing a click sound that happens when you hard power it off (holding down the power button) and then repeats
What I tried already was resetting the power multiple times and also connecting with only AC adapter to no avail.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
James Chen exactly what happened when you "forgot about the rechargeable battery" and turned your laptop over?
完成的
@oldturkey03 what I mean by that was when I picked up the laptop to turn it around the rechargeable battery came out of its battery contact pins and the computer completely turned off
完成的
Yes, that is what I thought. Have you checked the connectors/cables and traces to make sure that nothing came loose or got pulled off?
完成的
Yes I have took each and every cable out and re connected them.
完成的
添加一条评论
1个答案
最有帮助的答案
well this happened to my old computer and was told that i fried the board while trying to replace my hdd
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
James Chen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 559
