跳转到主内容
加入维修社区 - 创建账户
Panasonic Lumix 系列于 2006 年发布的一款 600 万像素相机。
Camera Will Not Power On - Was working previously
Hi,
I received a Lumix DMC-FX3 camera which had the lens jammed open due to sand getting in the mechanism. But it powered on then shutdown.
I manged to disassemble the lens and clean out the sand.
I tested the camera while still disassembled and it seemed to work - the lens mechanism was still a bit noisy so I decided to remove all the grease and clean it thoroughly before applying fresh grease.
When I assembled the unit - it now longer powers on.
There is no sign of life - no flashes from the LED no noise from the motor.
I charged the battery and checked & cleaned all the connections with isopropyl - but still nothing. Completely dead.
It seems to me like a protection fuse might have gone - but I can't easily find on on the pcb.
Does anybody have any experience of this camera?
Or have the service manual for it?
Thanks,
Mark.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
markiexxxx, here is the service manual. It does have the schematics, diagrams and parts list for your camera, hope this will help. Good Luck
这个答案有帮助吗?
得分 3
添加一条评论
oldturkey03 - I have the similiar problem, with lens zoom issues, could you please provide access to the manual to caravanwalks.
Thanks in advance
Update
thanks very much have accessed the information, now need some time to strip down the camera :-)
这个答案有帮助吗?
得分 0
1条评论:
it should be back up. Use the link from the above answer. I do have to remove them every now and then since I only have limited bandwidth....;-) contact me on my email in my profile if you can not download it. Good Luck
由完成的
添加一条评论
Does anyone know where you can get the 'Extension cables for servicing' from? Testing is impossible with the circuitry all assembled :(
这个答案有帮助吗?
得分 0
1条评论:
Would you by any chance have the part number for the cable?
由完成的
添加一条评论
Hi,
Yes they are:
VFK1951
VFK1974
VFK1950
VFK1951
RFKZ0362
VFK154
Thx
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
markiexxxx 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 2,560
