跳转到主内容
加入维修社区 - 创建账户
微软 Surface Pro X 的维修指南和拆解信息。这是一款基于 ARM 架构的 Windows 平板电脑,于 2019 年 11 月发布。
Surface Pro X SSD Swap
I notice that the SSD in the Surface Pro X looks a little different than the pictures I have seen of potential replacements (still looking, have not found any available). The connector has only one notch and it appears quite a bit thicker. Is there some shielding that needs to be removed or moved to new SSD?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Have since returned the Pro X and went for a Laptop 3 due to Win10 issues. Same SSD so process still applies.
Thank you.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
No issue that I have found. There is a post here on replacing the SSD.
Microsoft Surface Pro X SSD 更换
There are several options but I’ve only personally done it with the Kioxia BG4 M.2 2230 SSD.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Valther Nielsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 28
过去 30 天: 49
总计 829
