跳转到主内容
Repair guides and disassembly information for Microsoft's Surface Pro X, an ARM-based Windows tablet, released in November of 2019.
6 个问题 查看全部
Surface Pro X SSD Swap
I notice that the SSD in the Surface Pro X looks a little different than the pictures I have seen of potential replacements (still looking, have not found any available). The connector has only one notch and it appears quite a bit thicker. Is there some shielding that needs to be removed or moved to new SSD?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Have since returned the Pro X and went for a Laptop 3 due to Win10 issues. Same SSD so process still applies.
Thank you.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
No issue that I have found. There is a post here on replacing the SSD.
Microsoft Surface Pro X SSD Replacement
There are several options but I’ve only personally done it with the Kioxia BG4 M.2 2230 SSD.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Valther Nielsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 339
