跳转到主内容
加入维修社区 - 创建账户
2011 年 6 月发布的 10.1 英寸安卓平板电脑。 三星 GT-P7510MA
Touch Screen Replacement problem
I replaced the touch screen on my tablet and now have a thin verticle line on the left side of the display. Other wise works ok.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Did you buy the LCD and digitizer unit as one or the separated version?
由完成的 分享
@casp3rtech Separated...
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
Tracy Walker double check your work and check the connector. Make sure that everything is properly seated and that the LCD connector itself does not have any bend pins, debris etc. if everything checks out okay then the issue is a bad LCD.
这个答案有帮助吗?
得分 1
2条评论:
Everything looks good connector-wise. The digitizer worked fine before I replaced the touch screen; even worked ok with the old, cracked screen in place. Like you I can only conclude that in the process of changing to the new one, something occurred to damage the LCD. The connector for it was never unhooked, so can't imagine how it got damaged. ..
由完成的 分享
Can agree on that, something happened during the install and the lcd got damage.
由完成的 分享
添加一条评论
添加你的答案
Tracy Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 15
总计 416
