跳转到主内容
加入维修社区 - 创建账户
处理器:Intel® Core™ 2 Duo 处理器 T5750 2.0 GHz
Black or dead screen
My laptop seems to work when Turn it on.. I can hear the fan and hard drives working but the screen stays black like as if I hadn't turn it on or anything. Is the screen broken or is it loose..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
what I recommend you do first is to plug an external monitor into your computer. If the external monitor works, you know that your motherboard/GPU works and you can concentrate on the LCD. If you shine a light i.e. flashlight across your screen and you can see the outlines of your desktop, just very dark, you know its the backlight or inverter of your LCD. If you move the screen slowly up and down and you see lights flickering etc. it's your cables. You will find out more when you trouble shoot it one step at the time. If you need to replace the screen, the guide for it is here. Most likely it’s either bad inverter or failed backlight lamp. You cannot tell which one is bad until you test the laptop with a known good inverter. If I would have to guess, I'd replace the inverter board first. It’s easy to access and replace, and it shouldn’t be very expensive. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Shalamo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 5,754
