跳转到主内容
加入维修社区 - 创建账户
2015 年 1 月发布的安卓平板电脑。Dell Venue 8 7840 配备 8.40 英寸电子显示屏,分辨率为 2560 x 1600 像素。
Screen Tearing and Low Battery
NOTE: Not a Dell Venue 8 7840
Hello, Recently bought a Used Dell Venue 5050 (Not Pro) it booted up fine then Last Night i started getting Screen Tearing wondering if its the battery or the O.S.
Also its running android Lolipop
And Battery was only holding 25% Charge as of Last Night
Thanks in Advance, Andrew
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@born7 screen tearing should not be a battery issue. That is usually caused by the OS and/or memory. Try to charge your battery completely and then reset your software.
这个答案有帮助吗?
得分 1
3条评论:
Then what would you recommend how do i run tests for bad memory or O.S. on Android or do i have to connect it a computer and factory reset it
Also how do you go about factory resetting this model of Dell Venue (5050) (Non Pro)
由完成的
@born7 for a reset, this should work for your tablet. https://www.hardreset.info/devices/dell/...
由完成的
now this "Battery was only holding 25% Charge" could definitely be a battery issue.
由完成的
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 298
