跳转到主内容
加入维修社区 - 创建账户
LG G Pad 8.3 4G 是一款 8.3 英寸(21 厘米)的触摸屏平板电脑,由 Verizon 于 2013 年 10 月发布。通过后盖底部以黑色墨水印刷的 FCC ID “ZNFVK810” 即可识别此款平板电脑。
Opened device looks different!
Hi,
Pried the screen off and what I see is totally different from the picture in step 2.
It appears that I am looking at the backside of the battery.
The LCD is to the right, the left side shows the back side of the battery and the frame covering the battery.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
I know the black frame should be at the back of the LCD but that was the only way I could pry this thing open.
Model is LG-VK810
完成的
I have added a pic of the back panel. It's different from the video you sent me.
完成的
添加一条评论
1个答案
最有帮助的答案
@esebm totally possible but you need to know which guide you followed. Only you know where you started from. Post some pictures that show what you are looking at with your QUESTION. That way we can probably help you out further. Also, let us know what you are trying to fix. 在已经存在的问题里加入图片
Update (10/31/2019)
Looks like the black frame on the left should be on the back of your LCD on the right. What is the actual model number for your tablet?
这个答案有帮助吗?
得分 1
11条评论:
I followed that guide: LG G Pad 8.3 4G Battery Replacement.
When I pry the display off I don't see the pic in step 2, just the plastic frame.
There must be a way to pry off the back panel in order to get to the battery.
完成的
It sound sto me that you got somewhere under the LCD and separated that (the LCD from the frame) one. the guide you described is the right one so that is not it. Again, pictures of what you are looking at would help us to help you.
完成的
Yes, I did separate the LCD from the frame, that's how I interpreted step 1 in the guide. The back panel can not be removed by moving the spudger around the perimeter. The back panel on my unit is about 1/2" indented top and bottom and does not go around the perimeter.
完成的
Any help here?
完成的
Sure looks like you used the wrong guide. Looks like you pulled the LCD of the motherboard. Take a look at this video https://www.youtube.com/watch?v=27azAfFh... around 1:19 you see your LCD and sure looks like what you are looking at on your picture. If your LCD is still connected etc., you can always try and repair it by following the video
完成的
显示更多的6条评论
添加一条评论
添加你的答案
Ed Miller 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 14
总计 544
