跳转到主内容
The Dell Chromebook 11-3120 is an affordable, lightweight laptop that is most commonly used in professional and educational settings.
Chromebook not powering down when closing lid
CB will not power down when you close the top lid. Or go in to sleep mode.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
can you give me more info on what happens
完成的
does the screen stay on?
完成的
yes, I found the problem. the magnet on the backside of the bevel came out of its bracket.
完成的
@Justin Jordan yup just as I thought if the Chromebook does not read the magenet it does not go to sleep. is that all?
完成的
yes, thanks.
完成的
显示更多的2条评论
添加一条评论
2个答案
已选择的解决方案
solved magenet came off bracket
这个答案有帮助吗?
得分 0
2条评论:
Where is the magnet located? I’m troubleshooting a CB right now that will not sleep when the lid is closed… The option to sleep when the lid is closed is enabled.
完成的
Porque mi laptop se bloquea cuando le pongo la batería
完成的
添加一条评论
最有帮助的答案
It is built into the bezel.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Justin Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 33
总计 3,189
