跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
PS4 not recognizing LAN cable
I was having issues with my WIFI connection so I switched to a LAN cable. My PS4 says to connect a lan cable when I am setting up network settings, but it is plugged into both the PS4 and router. The cable works on other devices but it is not recognized by my PS4.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
I had this problem too but now it says that it cannot connect to the server within the time limit
完成的
添加一条评论
15个答案
最有帮助的答案
Hey this probably won’t help but I restarted everything including my ps4 blew any dust out of the ports Turn to connect to Wi-Fi off viewed connection status then went and set it up again and it worked
这个答案有帮助吗?
得分 2
1条评论:
I can connect my ps4 to my wifi but not my lan cable. The game is also constantly lagging.
完成的
添加一条评论
Not sure if anyone is having the issue still. I was with using an enternet cable. None of the above ways worked for me which I was screwing at! But I finally found out how to sort it! I updated the ps4 in safe mode. Turning the ps4 on and holding down the 7 seconds. Then choosing update system software, it rebooted and bang! It worked. No more working with 10mpbs. Back up to 125mpbs!
这个答案有帮助吗?
得分 1
3条评论:
what if the system says it’s already up to date, then what ?
完成的
Good question
完成的
125 GB is not fast. How do you get the gig speed right now I’m getting 385 megabytesper second.
完成的
添加一条评论
Two things that came up to my mind:
  • Have you checked if there is no dust collected in the ethernet port?
  • Look under connection status and see what information your router is giving your PS4. You may have to re-enter it manually (even if it’s set to automatic).
这个答案有帮助吗?
得分 0
6条评论:
I have checked, it runs on my laptop with no issues but when i go to change my PS4 from WIFI connection to a LAN connection, is where the problem is. I just get a screen telling me to connect a LAN cable when it’s plugged in
完成的
Is there no dust inside the LAN port? Is it possible to test somewhere else? It’s not easy to replace the port as it’s directly soldered on the motherboard. What kind of issues do you have with the wifi ?
完成的
My PS4 will download things in rest mode and stay on the dashboard with no problems but when I play games, is when it starts the issue. Every like 20-30 minutes, it will say WiFi connection lost, but as soon as I get that notification, I can rejoin a party because it’ll say I’m offline for about 3 seconds, no joke. I am able to rejoin a party before my party members see that I was left the party.
完成的
Sorry for the late response! It could be a lot of things. Your Wi-Fi card or your antenna or maybe something software related. I had this issue too, keeps disconnecting from the internet two times. One time it was a bug in the game and the other time it was my router causing some trouble (firmware update helped). Do you have this issue with all your games??
完成的
Any update my ps4 has bad speed on WiFi so I tried to connect to cable but ps4 not Recognizing it
完成的
显示更多的1条评论
添加一条评论
Please tell me you got an answer to this, it just happened to me today and I have no idea what is causing it
这个答案有帮助吗?
得分 0
4条评论:
That is keeps disconnecting from Wifi ? Or does it not recognize the LAN cable?
完成的
Hi, I am having this problem since 2018. So then I switched to WiFi, but my WiFi isn't very good. And now I want to use a LAN cable, but it keeps on saying LAN cable is not connected. I have tried switching my router, LAN cable, MTU settings but nothing helped. I also have tried rebuilding the database on PS4 but nothing helped. It's really annoying.
完成的
I got same issue, now I'm waiting for my ps4 to came back from warranty service
let's see what they say about it.
It looks like it is a pretty common issue :S
完成的
At the end I called PS service on last day of warranty and they replaced the main board
for me it looks like the ethernet chip is faulty
完成的
添加一条评论
I’m having the same issue. I’m trying to use a Cat 5e cable bc that is what is running through the house. If there are any suggestions, tips, or fixes, please let me know.
thank you
这个答案有帮助吗?
得分 0
3条评论:
I am having the same issue can someone help.
完成的
I found out exactly what the problem is. It is definitely not the PS4. It has something to do with your internet connection network settings. I was in my brother in laws house and no fix went home and connected to my internet with the Ethernet cable and boom it works.
完成的
Any idea how to fix the internet connection?
完成的
添加一条评论
Did you checked your cable? Is it working fine?
这个答案有帮助吗?
得分 0
添加一条评论
Yes, but no matter how many time I connect it just doesn’t work
这个答案有帮助吗?
得分 0
1条评论:
I keep getting a blue screen saying connect the DualShock controller and I keep doing it over and over and let it nothing happening
完成的
添加一条评论
I need help fixing my internet on my ps4
这个答案有帮助吗?
得分 0
添加一条评论
Same issue here. New cable. Tried multiple ports. Other playstation connects fine its just this one. Its never been able to connect via LAN.
这个答案有帮助吗?
得分 0
1条评论:
The problem is that when the RJ45-plug snaps into the PS4 the connect is lost. When unsnappinf and plugging back in, before the click, the connection works....
完成的
添加一条评论
Possible Causes Why PS4 Lan Cable is Disconnected:
Different players experience different reasons, and that is why you need a diverse collection of methods to try to fix your PS4 Lan cable disconnection issue. The issue could be due to;
  • Updated PS4 Pro firmware
  • A faulty cable.
  • A flawed Ethernet port, etc.
Solutions to fix PS4 Lan cable not connected:
  1. Restart your router
  2. Insert LAN cable ‘halfway’ through to the port
  3. Modify DNS settings on PS4
  4. Establish static IP address for PS4
  5. Rebuilding database on your PS4
To lean more about how how to establish static IP and modify DNS check this article
https://www.geexshow.com/how-to-fix-ps4-...
这个答案有帮助吗?
得分 0
添加一条评论
I’m trying to connect to my wireless internet but it’s switching on its own to lab cable and I don’t have lan cable I’m trying to go wireless which I have been doing for a couple of years
Can anyone help me
And asking for proxy server when I go wireless fyi
这个答案有帮助吗?
得分 0
添加一条评论
Is your LAN cable a cat7 or Cat8 Ethernet Crossover cable? I don't think a standard cable will work properly,
这个答案有帮助吗?
得分 0
添加一条评论
I am connect to the internet but can’t connect to the online serveres
这个答案有帮助吗?
得分 0
添加一条评论
My ps4 won't connect to wifi wirelessly or through lan. Ive hooked it up to my hotspot it works but slow. Ive bridged it with another ps4 in the house on the same wifi service and it works. Any idea what I should do its been going on over a year. Ive had isp tech come out multiple times they blame the device (mind you this isn't the only device that can't connect witelessly) they replaced router, ont, wires. Nothing works please help its mainly for my 13yo autistic son he doesnt really understand and is getting frustrated.
这个答案有帮助吗?
得分 0
添加一条评论
Same issue. When you try new cords, and every other device connects fine than it’s obviously the ps4 which is partly why I bought a series x
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nik Mora 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 54
过去 30 天: 235
总计 100,061
