跳转到主内容
加入维修社区 - 创建账户
Asus ROG 是一款游戏笔记本电脑,可通过其型号 G750JM-BSI7N23 进行识别。这是一款第四代笔记本电脑。Asus ROG G750JM-BSI7N23 完全支持蓝牙功能,配备全高清显示屏和 1 TB 存储空间。
How do you replace lcd video adapter cable?
how do you replace the video adapter cable on LCD screen . mine is danged but i cant find any info online on how to replace it .
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@donniedanko LCD to video connector? What adapter?
完成的
Yes to the video connector I found part just not sure how to install it heres what I'm talking about https://www.amazon.com/dp/B07N1HFF3K/ref...
完成的
添加一条评论
1个答案
已选择的解决方案
@donniedanko the part you would need is called a LVDS cable and yours should be Asus part number 14005-00890600 This video will at least get you into your laptop to get you to disconnect the wire on the motherboard. After that it gets a bit tougher since we don't see what your LCD display cover etc. looks like. Bezels usually just snap off and some of them are screwed in to hold the LCD screen in place. So we would need to see more of that. 在已经存在的问题里加入图片
Of course you can always check a slightly different model since the principal of the replacement is very common to most models. So something like this may work for you.
这个答案有帮助吗?
得分 0
1条评论:
Okay thank y'all very much for the fast responses. I'll try and get pics and check out video aswell.
完成的
添加一条评论
添加你的答案
donniedanko 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 14
总计 1,006
