跳转到主内容
加入维修社区 - 创建账户
HP Pavilion dv4t 14.1 英寸宽屏笔记本电脑。
remove or disable finger scanner
hi.
i recently purchased this laptop on craigslist and when i received it the finger scanner is on. so now i am unable to enter the laptop because it's asking for the password and or finger to be swipped. the person whom i bought from just said is now M.I.A- missing in action!
so if someone can help me or direct me that would be greatly appreciated.
thanks!
edie
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
as I was reaching for the hammer something told me "hey don't do it" so I didn't! All, i was able to remove all passwords. By 1st removing the actual finger reader, then I turned, turned off then turned on, I pressed f11. System Recovery, I selected Microsoft recovery files. I clicked on that and recovered original files and it ran for about 20 minutes. When it was completed, it restarted and long and behold I was in! Went to Control Panel/Users/removed all passwords and users. And happy to report my HP is running smoother than smooth without any passwords. I want to thank all for ur help and suggestions! Trust with out I would not be able to have completed this minor headache! Now that this is fixed, what do i do next?
这个答案有帮助吗?
得分 2
2条评论:
Accept the answer that helped you the most. If none did just change your comment to an answer and accept it. this way anybody with problems like yours will know what worked. Good job...;-)
由完成的 分享
Accept your answer so the question can be archived and used by others. +
由完成的 分享
添加一条评论
My advice is to just reset the computer to its original factory setting. When you first start your computer start hitting F11. This should launch the HP restore utility. Choose the option that erases all user data and programs and problem solved.
这个答案有帮助吗?
得分 1
2条评论:
I tried f10 and it was not what I was suppose too see. Like I mentioned my battery died, so as soon as UPS delivers my charger I am going to try f11, and keep u posted! thank u!!!
由完成的 分享
Your welcome!!! Do let me know how it goes or if you have any other questions.
由完成的 分享
添加一条评论
I had a VAIO with this, the easiest way is see if it is connected sepratley
Also, I hated it so much, uninstalling the HP software and driver for it may do the trick like on my VAIO but it had Linux so it was no longer a pest after XP slowed down like crazy
Uninstall all of HP's rubbish and you will find it and speed the laptop up, except Support Assistant
这个答案有帮助吗?
得分 0
4条评论:
Thank you, I'm going to try but until Monday or Tuesday ordered online, my laptop didn't come with a charger (great) the battery that it did have died. :( Meanwhile, I will begin my spec research. Either way I will try and let u know the outcome. Thank you, greatly appreciated!!!
由完成的 分享
hello! i tried F11 and nothing happened??? As for the finger ringer I went ahead and opened the laptop and removed the finger ringer. Now as i turned on the laptop and it's still asking for a password, as for the finger ringer it stats can not locate reader. That is a good thing right?
So what should I do now? Its still asking for a password?
Thanks!
Edie
由完成的 分享
When you first start up the computer it should say press F? for system recovery.
由完成的 分享
Glad to hear you got it to work!!!!!!
由完成的 分享
添加一条评论
If "disconnect the finger scanner" is something you would like to know how to do, read on...
- Follow the HP instructions on how to remove the DVD drive: Mainly disconnect the AC, turn the laptop around. Remove the battery, remove the wireless/memory cover. You will see a small shiny prong sticking out, unscrew it and then push it out (towards the DVD drive).
- After the DVD drive is out look at the opening (with a flashlight if needed) and you will see the fingerprint reader and connector. With a correct tool (in my case a small, long and thin, bent nose plier) disconnect the thin cable.
- Now you can either tape the end of it and/or push it to the back or tape it close to the connector.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
edie 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 23
总计 2,858
