跳转到主内容
加入维修社区 - 创建账户
ASUS X540S 于 2015 年发布,是一款 15.6 英寸笔记本电脑,配备板载图形处理系统,支持输出 HDMI 视频。
How to replace fan
My laptop kept shutting off so I opened it up and seen that the wires are broken, I think from overheating? The red one connecting the fan is completely split in half, all the rest just look like the outside covering has melted. I put the laptop back together & now it smells like burnt plastic. I can buy a replacement fan but just don’t know how to replace it & don’t wanna ruin it more than it is. Please help. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@aveja04 you did not give us your laptops make and model. Here are instructions on how to get to it for the device you selected.
Burned wires etc. is not usually a sign of a bad fan. that sounds like there maybe other issues. Post some good pictures of your fan, wires, etc., with your question so we can see what you see
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
添加一条评论
Check if the fan port is still safe, and try not to use your laptop otherwise you’ll break it or in your case melt it and it can cause irreversible damage.
Since I have a similar model, I can guide you to replace your fan, I will highlight the main steps for now because I’m not at home.
You already took off the keyboard/mousepad so I will continue from there, now you need to remove these components:
  • Battery
  • Hard drive / SSD
  • Wifi
  • Optical drive
  • Screen cables
  • Any other cable connected with the motherboard (like extra USB ports)
As I remember the motherboard is a little bit tricky and you have to removed softly but since you melted some plastic and I don’t know what else, then you need to be careful with it, could you add a photo after you unplug everything from the Mobo?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lorissa Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 376
