跳转到主内容
The second generation Pathfinder was introduced in late 1995 with more rounded styling. It was completely redesigned from the first generation, switching from body on frame construction to unibody construction.
My pathfinder turns over but wont start
It will turn over but won't start. It is getting fuel and sparking. I just had the exhaust repaired. It ran for a few minutes but when I started it up again it shut off and won't start back.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What was the exhaust repair?
完成的
Not a gear-head here, but a quick search for common culprits gave me this rather detailed troubleshooting overview:
https://shop.advanceautoparts.com/r/car-...
Some further digging suggests that, if it isn't the common reasons then it could be a failed camshaft or crankshaft position sensor
完成的
添加一条评论
2个答案
My suggestion would be to replace the fuel filter. Maybe some sediment in the gas tank got sucked into the filter when you ran the vehicle on low fuel. This sounds like a textbook issue of a clogged fuel filter.
这个答案有帮助吗?
得分 0
1条评论:
Jessica the OP stated that " It is getting fuel and sparking." How would that correspond with a clogged fuel filter?
完成的
添加一条评论
When you work on your car and it does not work after you are finished, you broke something in the area where you was working, the crank position sensor CKP is probably near the back side of the engine, I would guess that a wire is broken in the exhaust area where you was working, do a very good inspection.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
heathernkelly0126 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 1,784
