跳转到主内容
加入维修社区 - 创建账户
Nikko 出品的遥控方程式超级越野车。
Problem with Nikko Landshark
Bought a Nikko landshark without battery. So i connected a other i had lying around an put it to on. IT moved for couple of minutes and the it stuttered and stops. The battery is now recharged and is does not want to move.. I dont see lose wires or anything burned and dont smell anything. Does somebody knows wat the problem can be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
does your battery voltage match the original one?
由完成的
No, its different
由完成的
More or less, please provide us with more information (values).
由完成的
Its a Landshark. I got part removed and disconected battery tray. I place 8.4 battery on the wires and then i was driving with for couple of minutes. Then is stopped and now it does nothing. Nothing is burned as far as i can see. And all wires are good and not lose
由完成的
添加一条评论
1个答案
已选择的解决方案
Dennis the original battery was a 6.0V 620mAh so you need to tell us what battery you are putting in. After that you need to use your multimeter and check for the power leads etc. going to the main board. Without the basic information we can only guess.
Apparently the Landshark was known for very poor battery life
Update (09/16/2019)
It's a 6 volt system and you used a 8.4V battery? Check your power board for burned components (you will have to measure the values ) and check your motors to see if they are still working.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dennis 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 26
总计 565
