跳转到主内容
加入维修社区 - 创建账户
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Replace Optical Drive with SSD
Is it possible to replace the optical drive in a mac mini A1176 with an SSD? The interface of the optical drive is listed as pata, but looks to be a 50-pin connector supplying power as well. Whatever that interface is, I'm looking for a sata ribbon adaptor for it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
The left hand column on this link to OWC shows upgrades for your machine including a SSD drive: http://eshop.macsales.com/shop/mac-mini/
这个答案有帮助吗?
得分 2
2条评论:
mayer,
the ssd upgrade on that link appears to replace the existing hd in the mini. I'm looking to replace the optical drive with another ssd.
完成的
添加一条评论
You are correct, it uses a PATA connection, and in order to use a modern (half decent) drive, you would need to convert the connection from a PATA to a SATA drive. Of course these are still IDE connections, just different interfaces given the project.
A convertor like this would work: http://firmtek.stores.yahoo.net/seritek1...
The issue is then compatibility. To be honest, I know that Apple has never truly supported PATA to SATA connections, but that doesn't mean that it won't work.
这个答案有帮助吗?
得分 0
1条评论:
knowitall,
thanks. ive ordered a similar circuit card based adapter from amazon, waiting for it to arrive. im hoping for a cable solution, but no luck so far. goal is to fit the whole bundle back within the mac mini case.
完成的
添加一条评论
添加你的答案
paul 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 38
总计 4,918
