跳转到主内容
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 个问题 查看全部
Replace Optical Drive with SSD
Is it possible to replace the optical drive in a mac mini A1176 with an SSD? The interface of the optical drive is listed as pata, but looks to be a 50-pin connector supplying power as well. Whatever that interface is, I'm looking for a sata ribbon adaptor for it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
The left hand column on this link to OWC shows upgrades for your machine including a SSD drive: http://eshop.macsales.com/shop/mac-mini/
这个答案有帮助吗?
得分 2
2条评论:
mayer,
the ssd upgrade on that link appears to replace the existing hd in the mini. I'm looking to replace the optical drive with another ssd.
完成的
Use this: [关联产品丢失或禁用: IF107-079]
完成的
添加一条评论
You are correct, it uses a PATA connection, and in order to use a modern (half decent) drive, you would need to convert the connection from a PATA to a SATA drive. Of course these are still IDE connections, just different interfaces given the project.
A convertor like this would work: http://firmtek.stores.yahoo.net/seritek1...
The issue is then compatibility. To be honest, I know that Apple has never truly supported PATA to SATA connections, but that doesn't mean that it won't work.
这个答案有帮助吗?
得分 0
1条评论:
knowitall,
thanks. ive ordered a similar circuit card based adapter from amazon, waiting for it to arrive. im hoping for a cable solution, but no luck so far. goal is to fit the whole bundle back within the mac mini case.
完成的
添加一条评论
添加你的答案
paul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 4,642
