跳转到主内容
加入维修社区 - 创建账户
用于电脑或其他带视频输出设备显示屏(或监视器)的维修指南。
Monitor turns off randomly.
I have a BenQ 27 inch monitor. I hook the monitor to my laptop to have a larger display. It was working fine for a year.
The issue:
Recently the monitor shuts off every 1~2 minutes, and after another 1~2 minutes turns back on. This cycle goes over and over. A few observations are as follows.
  1. During the turn off, its green power button also turns off (the power button will not become orange). That means, it is not just the display that goes off, but it seems the whole power of monitor goes off. I suspect this is a power issue.
  2. During the time when the monitor is on, there is no problem with the display itself. I doubt it this is the issue with the graphic card of a driver related issue.
  3. Changing the power cord, or power outlet does not help. It is also connected firmly.
  4. Changing the cords of either VGA, HDMI, Display port and their connectors does not affect the issue.
  5. Using a different laptop/PC or operating system connected to the monitor does not affect this issue. Also, my laptop works fine with other monitors.
My attempt to fix it:
I suspected this might be a bad capacitor on the power board. I neither found a bulged capacitor by a visual inspection, nor there was a smell or noise from capacitors. However, I ordered a couple of capacitors online with the same specs, and replaced some of them on the power board. The issue still persists.
Question:
I do not think I am able to find which component on the board is causing the issue. So, I want to just order a whole board from a vendor.
Before spending time and money on ordering a board, I want to (almost) make sure if it is the power board issue at all, or maybe the main board (graphic board) issue?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
13条评论
i have the same problem tho, when playing monitor turns randomly off
由完成的
did you manage to find the problem? i seem to have exact same problem, though i do lick the over heating idia as some of the solder joints were burnt, im going to try run the monitor with no back on it and see if that fixs the prob if it does i will repot back though this will not be a fix and ill have to think of a way to incorprat a fan in the case lol
由完成的
im going to start a new thread with my prob and solutions as whith the back off and boards exposed it still blinked in and out however with a fan blowing on the exposed boards it did stay on though got very buzzy and after several minits horazontal lines were blurung the screen ill link to my post later maybe it will help :) btw arcad3blood nice idia on the fan :)
由完成的
Unfortunately, I was not able to find the cause of the issue. Besides replacing some of the capacitors myself, I eventually ordered a new power board from Benq customer service, and it did not fix the issue either. The issue could still be from other components of the power board, or from the graphic board. Anyhow, I did not spend more money on replacing other components as it eventually becomes more expensive than buying a new one. I got another new monitor.
由完成的
显示更多的8条评论
添加一条评论
7个答案
已选择的解决方案
@siasunny from your description of this it most certainly sounds like a bad power supply. The only way to make sure it is would be by having a schematic and measuring outputs etc. Since those are not readily available for further troubleshooting, I’d go and purchase a power board and try it out. Purchase from somewhere that has a good return policy just in case it is not.
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
I had this exact same problem and I sorted it immediately by changing the refresh rate down in the advanced section of the display extender screen config. Type Display and choose extend display. Select the corrected screen then go to advanced. Change the refresh rate. Bingo, worked straightaway.
这个答案有帮助吗?
得分 5
1条评论:
Thanks. That seems to have solved a similar problem. A new Samsung monitor coupled to an elderly Windows 10 Dell Mini Box.
由完成的
添加一条评论
i don’t think so. first thing: power supply is not directly connected to your monitor. Second thing is if bad powersupply shut down graphic it would also shut down the whole system, as this would be a system failure.
PSU must be a super fckin creative to shuts only graphic card for few minutes. To be able to do that it basically would need an option like that builded itself in it. And since nobody cares about that they just would bring up an system failure instead. And actually if you overload them they mostly would just burn something up. If they were branded like be quiet!, most probable that they would burn itself, but if it’s a cheap crap from ebay or amazon, they will burn a part of your pc.
Besides there are many more “events” that would occur before it would even happen with bad power supply. I had similair problem and i just needed to clean and cool off monitor. Try to point fan on it and i think you will have an easy solution.
Besides i can’t have a bad power supply. my cpu uses 80w max peak and my graphic 200.
my psu is 600w gold from be quiet! system power.
300w going on what? Keyboard? Mouse? i don’t think so.
Besides my second screen doesn’t even flintch during these “shutting off” moments.
And tbh they are close and he creates a lot of heat.
这个答案有帮助吗?
得分 1
5条评论:
My monitor is not even warm. It shuts off randomly about once per day.
由完成的
It may be something that generates heat nearby. My monitor was shutting off because my second, older monitor was generating heat, and thus overheating first monitor.
由完成的
i think the OP is useing a stand alone monitor and is refering to the power board in the screen not the sysstems powerboard its self, im trying to fault find exact same problem the grapics beads again is the in the monetor board not in pc grapics card, i could be wrong though lol
由完成的
ARCAD3BLOOD the power board for the monitor not the computer. Read the original response by the OP ", it is not just the display that goes off, but it seems the whole power of monitor goes off. I suspect this is a power issue."
由完成的
It's different for everyone, but for me its the outlet, my outlet doesn't have enough power, or the monitor is taking too much power, so when i do something that is also connected to the monitors outlet, lets say a standing electric fan, when I try to change the fans power the monitor turns off because of low electricity
由完成的
添加一条评论
I changed the power cable, I have open it, test capacitors, test power board, nothing!
I don't know if anyone have this problem still, but I think I found solution.
1. Turn off the monitor
2. Press and hold menu button and power on the monitor
3. you will be in BenQ Service Page
4. navigate to timer reset
5. click OK and confirm in new dialog box
6. turn off the monitor and on again.
Problem solved.
这个答案有帮助吗?
得分 1
1条评论:
Does timer reset just change ?
Monitor On TIme = 0
Backlight on On Time = 0?
Why would timer reset solve this?
由完成的
添加一条评论
I’ve had this issue before and solved it by taking the monitor apart and cleaning the buttons with alcohol. Take the button board and squeeze alcohol on them while pressing the buttons over and over to help wash them out. Then leave it for 24hrs to be 100% all the alcohol evaporated. The inner button getting dirty can cause a tiny short making it turn on and off or even eventually get stuck off. Be liberal and push the buttons a lot, especially the power button. You’re trying to wash stuff out of the enclosed switch.
Mine was turning on and off for awhile before getting stuck off. I figured at that point I couldn’t make it worse so gave it a shot and saved me from having to buy a new monitor.
这个答案有帮助吗?
得分 0
1条评论:
Very important to use 99% pure Isopropyl Alcohol so no mineral salts are left by water. 70% is for disinfecting.
由完成的
添加一条评论
I was having the same problem with a 6 foot long HDMI cable.. replace this with a smaller 3’ newer HDMI cable.. no more blank-outs for now..
这个答案有帮助吗?
得分 0
1条评论:
Silver Silver the OP stated that "During the turn off, its green power button also turns off (the power button will not become orange). That means, it is not just the display that goes off, but it seems the whole power of monitor goes off." as well as "Changing the cords of either VGA, HDMI, Display port and their connectors does not affect the issue.""
由完成的
添加一条评论
I had similar issue were simply the monitor keeps on blinking as if it had lose cable
I replaced the cable and it worked for a few days and started again so did the same replaced cable again and worked for few days and started again blinking
Sometimes the Monitor would work other devices and not with few and sometimes it was very random
the problem i notice was my smart LED lights which were behind my monitor
I simply unplugged them because they making me go blind while troubleshooting the monitor
And the movement I unplugged them The monitor started working perfectly fine and it being perfect
The LED driver has a transformer in it and due its electric field it would disrupt the signal sent through the HDMI
So if anyone has a similar issue, check your LED lights or any other electronics close to the cable or the monitor
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sia 将永远感激不已
浏览统计数据:
过去 24 小时: 17
过去 7 天: 136
过去 30 天: 641
总计 201,652
