跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z3 Compact 于 2014 年 9 月发布。
Xperia Z3 Compact Power Button Problem After Battery Replacement
Greetings! I’ve been following the article to replace the battery for my Z3C. All went well, battery was replaced. But the power button seems to have a problem: phone would not react to it.
I was able to start it by connecting it via USB and fastboot. It starts OK, calls, camera, network is working fine. The only two things that don’t is power and camera buttons. I could not give a thing about latter, but I need the former :)
Any advice what could I do? Does it smell like a mobo damage or the main flex? Inspecting the cable did not yield any visual damage.
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Just to answer my own question - it was the flex cable indeed. After the replacement, the phone works good as new.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Andrey Zhavoronkov  if all of this worked before then I suggest that you double check your work. Check the ribbon cable connector, make sure none of the pins are bend etc. If the connector is clean and no bend pins it could definitely be the ribbon cable. As you probably already know Sony does not have schematics for their phones so anything deeper than the ribbon cable will be extremely tough to repair.
这个答案有帮助吗?
得分 1
2条评论:
Thank you. I've double- and triple-checked my work. I hope that it is the ribbon cable in the end. I'll order the replacement part and see if that helps anyhow. I find it a bit strange that the volume keys are working, but not power/camera.
由完成的
Remember that a bad flex cable can wreak all kinds of havoc. Hope that is the issue
由完成的
添加一条评论
添加你的答案
Andrey Zhavoronkov 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 28
总计 1,256
