跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Can everything be replaced
can everything on a iPhone be replaced or is it certain things? I really need my pictures off my iPhone but it wont turn on and the lcd screen is broken and my pictures are only on the phone(not on icloud or anything like that)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
You will need to troubleshoot the motherboard to get the photos off. The CPU handles the encryption and contains the key, so there is no way to switch NAND flash out willy nilly.
You will need to find a schematic and get a good multimeter for this job, or send it out for professional board repair.
这个答案有帮助吗?
得分 2
添加一条评论
@jo1234 the pictures are stored on a “chip” located on your logicboard so you cannot replace that. Everything else can pretty much be replaced. The question is now what happened to it that it does not come on. I would at least go ahead and replace the display assembly and the battery. A new battery may just have enough power to turn your phone on long enough to backup your data. You do not want to do any more if you are uncomfortable with doing those repairs. You could try to contact a microsoldering expert like @refectio and see what he thinks your next step should be.
iPhone 6s Plus 显示组件更换
iPhone 6s Plus 电池更换
iPhone 6s Plus 电池图片
指南
iPhone 6s Plus 电池更换
难度:
中等
15 - 45 minutes
iPhone 6s Plus 显示组件图片
指南
难度:
中等
30 minutes - 2 hours
这个答案有帮助吗?
得分 2
添加一条评论
yes, technically everything can be replaced but if you have an issue with the logic board, upon replacement you will lose all your pictures. you could possibly micro solder the storage off the motherboard and replace it with the new motherboard but that isn’t really a DIY type of thing. Hope this helped
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jordancauvel1998 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 106
