跳转到主内容
Is the keyboard connector replaceable?
MacBook Pro Retina 13” (Late 2013)(11,1)
2.4 GHz Core i5
My wife's built-in MBP keyboard has stopped working in a couple of areas. I performed an SMC and PRAM reset and it didn't help. Paired a bluetooth Apple keyboard, and it works just fine.
Keys not working on left side: F1, `, q, a, z
Keys not working on right side: F11, F12, delete
I’ve opened it up and can see no liquid damage. Upon disconnecting and reconnecting (reconnecting was difficult!) the keyboard connector, a few more keys became unusable. So I did it again and now it’s back to just the ones from before, leading me to believe there are some bad sockets in there.
Is this replaceable without welding? Edit: I may also attempt to replace just the cable, as that seems easier. I can’t see any issues with the connector itself, but the cable is questionable - the blue film around the connections is coming up in a spot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@daviddoes
Yes, it is but will require soldering. If you have never soldered on a logicboard I’d let someone else do it. I am not convinced that this is a bad connector. I am with you on the cable or even the keyboard being the issue. You would have to let us know the exact model of your MBP for further help.
Update (06/30/2019)
Looks like this is the only way to go MacBook Pro 13" Retina Display Late 2013 Keyboard Replacement
这个答案有帮助吗?
得分 3
10条评论:
Thanks. Edited OP to show model.
Also, it appears you cannot get just the keyboard cable. I've only found Trackpad cables. It looks like in the past, Trackpad and keyboard cables used to be one cable.
完成的
@daviddoes Keyboard cable is part of the keyboard and can't be replaced on its own.
完成的
I see that now, @arbaman. Looks like iFixit doesn't sell these, nor have a guide. Suggestions?
完成的
@daviddoes You didn't find it, but the guide is here ;) However, I believe you're right about the keyboard availability, but you can find it elsewhere online without too much effort. Here's the guide, hope you don't get scared, it's quite a bit of work:
By the way, it was originally posted already by @oldturkey03
完成的
Thanks so much, @arbaman
I'm not worried about it too much. The only things I haven't done is remove the battery and replace keyboard (so many screws!), which looks easy enough as well. The most difficult will be putting everything back together.
Do you know what adhesive would be best for the battery? I'm thinking E6000, since I have some on-hand.
完成的
显示更多的5条评论
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 934
