跳转到主内容
加入维修社区 - 创建账户
Garmin Nuvi 200 是 Garmin 200 系列 GPS 导航仪的一员。它于 2007 年 5 月发布。预装了美国全境、夏威夷和波多黎各的地图。提供经典银色或粉色版本。
Disabling usb mass storage mode
Recently I plug my USB cable into my computer and now I cannot get USB mass storage mode off my garmin nuvi 200w
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
2个答案
已选择的解决方案
The information provided is from here and explains why it does that. "Garmin Mass Storage Mode devices no longer communicate with a computer with the Garmin Protocol but instead present themselves as a USB mass storage device. When a USB cable is connected between a Garmin Mass Storage Mode GPS device and a computer, the GPS device enters mass storage mode." so you could try the reboot by :
1) Disconnecting the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi should now reboot, but remain in GPS mode!
The only other thing I can think of is that you might require a new cable, if this just came up. Good Luck and I hope this information helps.
这个答案有帮助吗?
得分 20
15条评论:
Thank you much for this fix!!!! It worked!!
Kathleen Marie
由完成的
you are very welcome ;-)
由完成的
Thank you, oldturkey03. Save me $$$.
由完成的
@Mark Koh, you are welcome.
由完成的
worked by pressing and holding it for a few seconds- thank you
由完成的
显示更多的10条评论
添加一条评论
I have Garmin Nuvi 260w GPS and Have a similar problem I did and fallow all the direction from Steps 1 to 4 as stated above ,GPS started showing running Visual Maps directions ONLY . Great. better than nothing ?
But found Talking Direction is stop working , GPS DONT want to Speech ? . I checked GPS Volume, Sound Settings, i.e. sound is Abled or Disabled, it is abled and also Couple of time switching either way but GPS Don't Give Voice Direction. It Works and Gives Both Sound/Visual Directions together at the same time before performing Fix steps 1 to 4. That means when working all alone on GPS battery and not connected to Car at all> Please advice if you good guys have any solution ?. Abee
这个答案有帮助吗?
得分 0
1条评论:
Thank you so much. Was ready to throw in the garbage and never buy a garmin again.
由完成的
添加一条评论
添加你的答案
mona 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 36
总计 41,797
