跳转到主内容
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
263 个问题 查看全部
My Dsi XL got wet.
The screen will blink once then turns off, the battery looks like it has a little corrosion on the conectors the red indicator light blinks when connected to charger but when I push the start button it goes to blue for a split second then turns off. Should I replace the battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Just treat it like any other device that got submersed Follow this guide and reevaluate after. Good Luck
这个答案有帮助吗?
得分 1
添加一条评论
Maybe you could try putting the battery in alcohol for afew minutes then get a cloth and let it dry then it, ll work just like new
这个答案有帮助吗?
得分 0
添加一条评论
fu this
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dg2898 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 2,775
