跳转到主内容
加入维修社区 - 创建账户
于 2017 年 6 月发布,是 Surface Pro 4 的继任者。也被称为 Microsoft Surface Pro 12.3 英寸。型号:FJT-00001。
Bad battery, need to replace
Hello. I think I may need to replace the battery in my Surface pro 2017 if it gets any worse. Two years after I bought it I only get 3 hours of battery life. I see you have a surface pro 4 battery replacement video but I can’t find any specifically for Surface Pro 2017. Do the video and the tools for the Pro 4 also work for the Pro 2017? Any advice would be appreciated. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
My customers surface only turns on when connect to charger
完成的
I bought a new battery ($50+) then cracked the screen ($200) and then broke the LCD touch screen connector ($10) which I am waiting for. So I’m in it for $260 to “change the battery.” Couldn’t find a place that would do it because the screen tends to crack. Not sure what I would do better next time but you may factor these costs in in making your decision to replace vs. buy new one. I had the same experience as you as far as battery life. I ended up buying a new Surface Pro 7 and am going to use my old one as a back up.
完成的
添加一条评论
1个答案
最有帮助的答案
@ilikegreen I would suggest to follow the guides and teardown from here After that proceed carefully the same way as the Surface Pro 4.
这个答案有帮助吗?
得分 3
2条评论:
Thanks for the advice.
完成的
I do not see a battery replacement guide help!
完成的
添加一条评论
添加你的答案
Richard Paulino 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 21
总计 1,955
