跳转到主内容
加入维修社区 - 创建账户
PowerBook 170 由苹果公司 (Apple Inc.) 于 1991 年与 PowerBook 100 和 PowerBook 140 一同发布。其外形尺寸与 140 完全相同,是最初 PowerBook 系列中的高端机型,搭载了更快的 25 MHz Motorola 68030 处理器(带浮点运算单元 FPU)以及更昂贵、质量明显更好的 10 英寸(250 毫米)有源矩阵显示屏。它于 1992 年被 PowerBook 180 取代。
PowerBook 170 does not turn on
My Macintosh PowerBook 170 does not turn on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
@reaowe you did not tell us how you did the reset. This is what Apple suggested many years ago:
Power Manager Reset
Reset the power manager if the battery and power adapter are proven good, but the computer will not power on. The computer will not reset after a system crash.
To reset the power manager in a PowerBook 140/145/145B/170,
• Remove the AC adapter and the battery.
• Let the unit sit without power hooked up for 3-5 minutes.
• Then, use two paper clips to simultaneously press and hold for approximately 30 seconds both recessed buttons (commonly known as the reset and interrupt buttons) located next to the power button on the back panel of the PowerBook.
• Reinstall the battery and, if necessary, reconnect the AC adapter.
• Turn on the computer.
If that does not work you want to check your AC adapter to see what the voltage is. Also, the Powerbook 170's don't power up at all if the PRAM battery is dead.The PRAM battery is located directly under the keyboard! Some PowerBook may require soldering two pins.
这个答案有帮助吗?
得分 4
2条评论:
Thanks! I already reset the PB Power Manger, from the following above. I think the PowerBook A adapter is working (at least the last time I tried when the computer was working). I decided not to replace the PRAM battery for now, the reason why the computer didn't ""turn on" was the display cable was not attached, the last time I have it open. I attached the cable and the computer powers up when the last time I left it before I opened the PowerBook 170. The PowerBook turns on with the startup sound, but does not show the missing floppy disk icon. It shows an blank screen and the hard drive spins. What should I do?
由完成的
Any thoughts on where to get a replacement PRAM battery? Is it a special type or easily available?
由完成的
添加一条评论
there are many possibilities, your battery is busted, your logic board is also may be busted, or it may be old. this computer os more than 20 years old so it might be worn out.
这个答案有帮助吗?
得分 1
2条评论:
I reset the Macintosh PowerBook Manger. With no success. I am running only on AC adapter. No battery, I took the battery out because it had corroded the battery terminals on the battery itself. The PowerBook battery terminals are I think fine.
由完成的
Ok good to know
由完成的
添加一条评论
Usually the AC adapter fails on these machines.
In fact, I haven’t seen an AC adapter in the last 5-7 years from these series PowerBooks that was still good.
But luckily, they are easily repairable, just need a complete replacement of capacitors. I repaired two in last year and they now work as good as new.
So, replace or repair your AC adapter (7.5V 2A) and see if anything changes. If you have a voltmeter nearby, check the output voltage on the adapter output jack.
这个答案有帮助吗?
得分 1
3条评论:
I tested the AC adapter with a multimeter so I think it works just fine. Thanks for the suggestion through. :)
由完成的
Anything else I can check or do?
由完成的
You must test the AC adapter with some load. Unloaded AC adapter might output 7.5V but drop when connected to laptop.
由完成的
添加一条评论
添加你的答案
Owen Ready 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 2,322
