跳转到主内容
加入维修社区 - 创建账户
Shark Pet Perfect II (SV780) 是一款 18V 轻便型无线手持真空吸尘器,能够进行强力清洁。
Runs for only one second
Shark 18 volt vacuum will turn on, run for one second, and then turn off.
Update (04/07/2019)
It’s an 18 volt hand held. Shark, model SV780_N. I thought it might be a bad switch. When I took it apart, I found the switch has a circuit board attached to it. Is this some kind of overload cutout? When I jumper across the switch(bypassing the circuit board) it will keep running, meaning the battery is good.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
2个答案
最有帮助的答案
Daughter has same model with same problem - runs for one second, then stops. She had replaced the battery which resolved the problem for a while. It is now experiencing same issue. Using a meter, I determined that the charging cord is working properly but the wires to the battery are not providing power to the battery to charge it. I opened the unit and found a circuit board under the switch; will add pics. Assuming the board provides battery charge monitoring, I bypassed the circuit and charged the battery for an hour (battery got slightly warm, but never hot). When I removed the bypass and tested the unit, it continued to run until I turned it off. Circuit board is too complicated for me to troubleshoot - a two-sided surface-mount board.
Update (12/29/23)
这个答案有帮助吗?
得分 2
添加一条评论
Paul Nowack  there really is not enough information on here. It sounds like a bad battery. It may not supply the required voltage needed and may fail under a load. Let us know what exact model this is and what you have checked.
Update (04/07/2019)
Thanks for the updated information. Would have been great to know ahead of time :-)
Post some good images of the switch PCB. Possibly some bad component on it and you should try to use a multimeter to see where the switch circuit is on that PCB.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Paul Nowack 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 85
总计 2,595
