跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
20 个问题 查看全部
Not charging correctly. Plz help
My Apple Watch series 3 got water damage a couple of days ago. I soaked in alcohol for a day and then let dry. When I plugged on charger, it showed the green charging sign. I unplugged it and replugged it and now nothing happens, except after 30 mins a screen covered in different color led shows up. When I unplug it dies instantly. Plz help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
I think you need a new battery.
这个答案有帮助吗?
得分 1
1条评论:
My watch also screen cracked & water damaged
I kept near the fan for whole day
Next day after puts on charger it booted up
But not charging it was stuck on 1% not increasing
Immediately I checked battery health on watch it’s showing service recommended
Previously it was 100%
I tried with 2 hours I put charger but no use
While plug it off after couple of minutes it’s been turned off
In my case replacing battery is solution or any other solution have to do
完成的
添加一条评论
I got this my d00d.
What might be the problem (this happens to me sometimes) is that your putting the Apple Watch on the charger and it would seem to be charging, but it isn’t. The charger has two sides, and one of them is magnetic, and the other one does nothing. You have to make sure it magnetically sticks onto the charger, and then something will appear on the screen saying it is charging. If that isn’t working, the charger may be broken.
Hope this helped my d00d.
这个答案有帮助吗?
得分 0
1条评论:
Thank you. But It sticks on, and the charger is broken cause it works on the other watch. If u can provide further info if be thankful.
完成的
添加一条评论
It seems to me from your description that the watch was never disassembled and you just placed the whole watch in alcohol. I recommend a full disassembly to inspect and clean. Apple Watch Series 3拆解
Electronics Water Damage
https://www.youtube.com/watch?v=DsDpALKQ...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ibrahim Asfari 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 6
总计 412
