跳转到主内容
Some things just don't quite fit in.
253 个问题 查看全部
What power connector is this video display use? (LiquidVideo LVM701)
I was given this because it was going to be thrown out and it appears it has never been used. However, I can’t use it in a car since it’s from 2003 (unless it’s incredibly old if the connector is nonstandard) and I’m missing everything to it outside of ONE additional RCA in cable that isn’t part of the unit. That said, if I can flip the video or create a upside down stand that’s stable it looks like it may work for a test monitor if I don’t need a full blown TV. My theory is it’s made for a European car (VW, BMW, Benz, etc.) since it’s robust looking but I don’t know much about it because it’s a Circuit City product and I can’t find a archived manual to come up with any clues. However, it could also look European but be universal considering where it came from.
I’m not concerned about the LAMP connectors since I don’t need them and they’re incandescent. I’d rather leave them unplugged to keep the power draw down and sin
Another option I may look into is taking scrap power cord that’s able to handle it and soldering a DC 12V (center positive) jack to the existing wire (and decapitating it) or making it secure but removable. I would consider decapitation considering how much it’s missing (plus it’s basically worthless on the used market) but I’d rather go modular to save the connector (even if I need to remove it; I already marked the polarity just in case).
I don’t know how many amps it needs, but it’s probably on par with most DVD players (~1-3 amps depending on the unit). It also doesn’t matter as long as I use a 12V adapter since it will only draw what’s required.
Here is a photo of the LAMP connector for additional reference. Not using it but it may help ID if it's generic or specific further.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@nick I am a bit confused by what you are asking. If you are looking for the female end of the 2 pin power connector, that may be difficult since we do not have enough information about this. I would suggest that you go to your nearest hardware store or automotive store and buy a new, complete (male and female) connector. The cost should be minimal and in that case you can still properly connect things and it will look professional. Something like this is what I would use.
这个答案有帮助吗?
得分 2
3条评论:
I was seeing if I could track down if it's nonstandard or vehicle specific. I figured if it was manufacturer specific I could try and find the right connector that way and save the stock connector; mainly to see if this is vheicle specific OR universal. I suspect European because of the connector size.
Yeah. I tried but much like everything sold by Circuit City the information is as dead as the company if it wasn't archived :(. I'm just as clueless to the degree you are. I even ended up giving up finding the manual because it's made of unobtainium unless I get lucky. I've provided what I have available to me and yeah... It's not much.
完成的
The connector is most likely not vehicle specific since the LVM701 is not listed anywhere as an available accessory marketed by any vehicle manufacturer. I am certain this was sold with the female end as a piggyback connector.
完成的
I see. Since it's probably some unusual connector that's probably obsolete (or hard to find) that probably rules out finding a compatible female lead and preserving it easily.
It was worth seeing if I can get away with it.
完成的
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 116
