跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A3 (2017) 是一款属于 Galaxy A 系列的中端智能手机。它由三星于 2017 年 2 月与 Samsung Galaxy A5 (2017) 和 A7 (2017) 一同发布。
Swap microphone with speakerphone mic?
Hi there. I’ve got a 2017 A3 whose usb port i was replacing,but unfortunately spilled flux to the mic hole nearby and i think i broke the mic. Can i swap this over with the speakerphone mic,instead of waiting for a new one?
Also,how resistant are these mics to heat? Could heat have broken it and not the flux? (didnt push heat through the hole,though. It had kapton on that side. Too bad the flux went through..)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
frizstyler  both Mic’s have the same part number 3003-001233 so they are compatible. Unlikely this is from the heat but most likely shorted out.
这个答案有帮助吗?
得分 1
4条评论:
thanks mate.
I’m not asking whether the mic’s are the same,i’m asking if it’s ok to remove the speakerphone mic and place it there.
由完成的 分享
Since they are the same mics you can just place it there.
由完成的 分享
but the speakerphone will have no mic. will the device work properly? thats what im asking..
由完成的 分享
frizstyler that will depend on your phone's firmware and if it does a self test on the mic. Most likely is that it will work. Eventually you would want to go ahead and replace the mic.
由完成的 分享
添加一条评论
ok i swapped them over and it works! Hmm.. dont know whether this affects the stereo sound of video though.. and noise cancelling must no longer be working…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
frizstyler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 734
