跳转到主内容
The HP 842c was introduced in 2000. Like most old printers, the cartridges are large and lasted for a long time, and were overengineered. However, it uses a tri-color cartridge which makes it so one color running out ends the entire cartridge.
5 个问题 查看全部
Is this sound bad? *With video and photos*
I think the unreadable string of text is from the ink running out but I am including an image just in case.
This printer has been my “go to" for years when I need to run rough drafts or make visual notations on a document for a guide I am making modifications to as an example. The ink is cheap and I can keep the wear off of my real printer.
However, I went to use it and it was a bit difficult to setup but I clearly got it going. However, it now makes those noises when I run a long print job (even with 2 page merging as I did for this to cut back on paper use). It persisted through the job (10 page) so I suspect it'll never go away.
Does this sound like a motor issue or something I can solve with new white lithium grease? I know where to get some so it isn't a problem to apply new stuff but it also sounds like a bad motor. I'm really looking for a second opinion on the issue. It's always made sounds someone who doesn't know better that sound bad but this is bad enough it's beyond a PEBCAK error.
Update (2/11/19)
I tried using white lithium grease on the gearbox in the printer (and the rail the ink carrier is on) and it doesn't make a difference. It still sounds awful.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
maybe its a motor issue
这个答案有帮助吗?
得分 0
添加一条评论
I would personally suggest that you just lube up the motors and their rails. That should fix the issue.
这个答案有帮助吗?
得分 0
1条评论:
White lithium grease didn't help the sound. There seems to be an issue with the motor as far as I can tell.
完成的
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 351
