跳转到主内容
加入维修社区 - 创建账户
配备 2.16 或 2.33 GHz Core 2 Duo 处理器的 A1200 机型
hard drive replacement manual
I have searched the manuals and cannot find one on the hard disk replacement of the EMC 2111 24" intel imac.
I understand that there is one but cannot find it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Doesn't appear to be one on the site. But for what it's worth, here's a Macworld article by Kyle Wiens describing the process, though (along with links to other ifixit guides for similar models): http://www.macworld.com/article/145116/2...
The key quote: "The later G5 iMacs and first Intel models are tough: They have nasty retaining clips holding the front bezel in place. Removing the bezel requires a flat pry tool, such as a credit card or ID badge. You also need to completely remove the LCD display and lower EMI shield before you can access the drive. Rating: Difficult"
这个答案有帮助吗?
得分 2
添加一条评论
Someone woke this one up after 3years, I thought I might as well update the answer. The guide for the hard drive replacement can be found right here
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
David Randall 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 2,658
