跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Why wont my iPad turn on?
  1. My iPad wont start, I’ve tried different methods to restart it such as pluging it in till a computer with iTunes but it wont get recognised. When charging the iPad gets hot in the higher parts of the right side. I would be happy to get help with what parts could be damaged and what to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
Connect your iPad to the computer and enter DFU mode by press/hold home button and lock button for 5-8 seconds, then release lock button while keep holding home button, after a few seconds you should get a prompt in iTunes - try restore iPad in DFU mode and see it can solve the issue.
完成的
I've tried that. But thanks anyway!
完成的
添加一条评论
1个答案
Well it could be a number of things first thing that comes to mind is that when you say it heats up is it when its on? Also do you see any icon or anything on the screen at start? If you don’t see anything on your ipad air it could most likely be a backlight which has gone out and may need to be replaced and since it heats up it may need a new battery since it shows symptoms of failing.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the answer! No I can't see anything other than that it heats up att one spot while charging.
完成的
添加一条评论
添加你的答案
Jonas Björs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 138
