跳转到主内容
加入维修社区 - 创建账户
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
No Network Connection even with a good sim
The phone says “No network connection”. And it has a little circle with a line through it where it would usually show signal strength. It wont make any calls either. I just put a brand new screen,frame,back glass and battery in it. Not sure if it makes a difference though. Any help would be appreciated as I am planning on selling my s9 soon to get the s10. Thanks! (I have already tried the SIM in another phone. It works fine.)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi Ethan,
Make sure that all your antenna cables are properly plugged in and intact.
Samsung Galaxy S8 主板更换
这个答案有帮助吗?
得分 1
2条评论:
I did. I just took it apart and they are all good
完成的
I ended up just removing the board completely again. After reassembly it worked for some reason
完成的
添加一条评论
Iam not an expert, but do check if IMEI number is there in settings. If not it will not recognize any sim card.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ethan Leroux 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 2,151
