跳转到主内容
加入维修社区 - 创建账户
After boot logo: www.apple.com/support?
Right after apple boot appears, screen shows a dead ipod cartoon with this website beneath it (www.apple.com/support). And suddenly ipod goes off. What can I do?.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
does your ipod charge properly? Is it being recognized under itunes? Did anything happen to it?
完成的
添加一条评论
2个答案
已选择的解决方案
Go into Diagnostic Menu by holding the center button and the menu button until the screen goes black, then hold down the center button and the back button. You should get to the diagnostic menu where you can run the internal tests. This should give you the opportunity to find out what is going on with the ipod Here is a video explaining it to you. MY first gut reaction is to say that it probably is your battery....Let us know what your diagnostics tell you. Of course, also try what Richdave is suggesting since it gives you a chance to see if you can access the ipod from your computer. Good Luck
这个答案有帮助吗?
得分 1
添加一条评论
Try forcing the iPod into Disk Mode
If that is not possible then you probably have a hardware fault.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Oscar Kelly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 3,233
