跳转到主内容
加入维修社区 - 创建账户
为 PS3 原配手柄提供的维修与支持。这款支持六轴感应、锂电池供电的手柄(CECHZC2)于 2007 年 11 月(日本)和 2008 年(其他国家)发布,维修简便。
Analog stick replacement CECHZC2E
I disassembled my PS3 Dualshock 3 controller, because the left analog stick has broken, and didn’t move back to the middle position. (Looks like the spring not functioning)
I desoldered the broken analog, and ordered one with the same pin layout (3pin version).
When the new part arrived, I had realized, while the number of the pins are the same, their position are different, so I cannot solder it to the PCB.
I searched on the web, but I didn’t find that type of analog stick, what I exactly need. (Just the 3 and 4 pin version, which are not what I need)
Do you have any idea or tip, from where can I order this kind of analog stick?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I am facing same problem, still couldnt find similar looking analog stick. All looks smaller like djjano1 posted and if they dont look smaller the micro switch looks like 6mm version instead 4.3mm like on this analog. I have same CECHZC2E B1 dualshock3.
由完成的
添加一条评论
5个答案
最有帮助的答案
djjano1 there are 3 revisions of the Dualshock 3 CECHZC2E, CECHZC2E A1 and CECHZC2E B1. Your analog stick looks actually more like a PS4 replacement
Check on places like this for a better replacement
这个答案有帮助吗?
得分 3
添加一条评论
Seems you have a new version of the controller, made for release with the PS3 Slim. Try looking for those parts. I couldn’t find anything quickly, but you can always try it yourself.
这个答案有帮助吗?
得分 1
添加一条评论
Same problem Here.. no fix yet…
这个答案有帮助吗?
得分 0
添加一条评论
Apparently this version is really successful fake controller, hence the differences. I used Xbox 360/PS2 analog and replaced the push button of correct size (way smaller). Had to create holes in plastic for button legs but it works. Cost was under 2$, button were actually more expensive (1$) as I had to order at least 10.
My original idea was to use inside of new PS2 analog and replace the original one, but dont remember why it was not feasible.
这个答案有帮助吗?
得分 0
添加一条评论
I'f this model was fake?? Why did I get it in the box with the ps3 phat and the ps3 super slim sealed from the sony factory…
这个答案有帮助吗?
得分 0
2条评论:
SCP toolkit refers to it as fake, on motherboard sticker is not Sony but something else (forgot what exactly and too lazy to open the controller). I found it in past on some site in search of these weird analogs that its supposed to be really well done fake. That would explain why there isnt single analog for this DS3. Believe me or not, up to you. Its possible to fix it and it works as new, thats what matters to me.
If you post PCB from both sides, I might be able to find the site which claims that its fake.
Edit:
Found it is Asuka board
https://www.psdevwiki.com/ps3/DualShock_...
由完成的
添加一条评论
添加你的答案
djjano1 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 41
过去 30 天: 112
总计 6,512
