跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Ambient light sensor not responding
After replacing a cracked screen, the ambient light sensor won’t function. The brightness in the display will not adjust even if I go from a dark room to outside and sunny. Tried putting a different sensor and front camera assembly from another iPhone 7 in just to check if it was responsive but no luck. Checked both of the sensor and front camera assembly on the other device and both are functioning on that phone.
On the new third party display, I have also scraped away the black paint in front of the sensor to let more light in and cover it up a bit with a black marker but still no luck. Have also tried to recalibrate both the sensor assembly but still not responsive. All other functions like front camera and etc work perfectly.
Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I have run into this issue before and it only worked with an OEM screen, we tried multiple after market screens and it would fail.
这个答案有帮助吗?
得分 0
1条评论:
Sounds weird but I will try to attach a OEM screen on the device to see if it responds then
完成的
添加一条评论
添加你的答案
Benjamin Hundershagen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 514
