跳转到主内容
加入维修社区 - 创建账户
Macintosh Color Classic 是 20 世纪 90 年代初的一体式彩色 Mac 电脑。
Problems with Macintosh classic
Hi,
The other day I found a Macintosh classic on the side of the road. When i tryed turning it on all i could hear was a screeching sound and the screen was not turning on.
The screen also has black specks on it and I can’t find what they are.
If anyone could help it would be greatly appresiated.
Thanks,
Angus.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Was the screeching sound followed by the sound of a car crash?
由完成的
The "car crash" error sound that Mayer is noting is in the video below at 0:15.
https://www.youtube.com/watch?v=4FOOmouk...
由完成的
No, the screeching noise sounds mechanical, not digital. I think it might be a problem with the hard dride.
由完成的
First: You have a Classic, not a Color Classic. They're very different. Might want to change the model in your original post.
Second: If you can post a recording of the sound on Soundcloud or YouTube that would help. In the meantime: Does the screeching sound start the moment you turn the computer on, or a few seconds after? Does it sound high-pitched and screechy, or lower-pitched and clunky? Does the monitor turn on (light up, display an image, etc) at all?
由完成的
@tronke good find on the error sounds. I had never heard it recorded before.
@secondlife there is no icon listed for the classic, so the color is as close as iFixit has.
由完成的
添加一条评论
1个答案
已选择的解决方案
Judging from the flaking, that CRT looks worn out. If you can find a nice one, replace it before good ones become even harder to find.
On these classic Macs, these problems usually come from a faulty analog board. Typically it’s bad capacitors or a flyback transformer. If it’s bad caps, this can be fixed but you may need to substitute some of the obsolete values and tantalum caps. If the flyback is bad, then you might as well get a tested/refurbished analog board and use this one for extra parts unless you can do the flyback swap.
CAUTION: CRTs can (and do) KILL. Do not wear any metal jewelry when you have the CRT and analog board exposed and discharge it. Most CRT’s made from the ’80s/'90s-present have a bleeder resistor, but this should be assumed to be burned out and discharged to be sure.
If you don’t know how to work on a CRT safely, read up on CRT safety before doing the repair and opening it. Take a look at this answer for CRT safety but DO NOT rely on it as your sole information source: Disassembling an old Apple monitor
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Angus Geraghty 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 32
总计 1,505
