跳转到主内容
加入维修社区 - 创建账户
Panasonic Lumix DMC-FH20 是一款 1410 万像素的数码相机。它有黑色、银色、红色、紫色和蓝色可选,是一款便携式傻瓜相机。
battery cannot be removed
after opening the compartment and releasing the lever inside the battery does not pop out as it used to and it can not be removed. how can it be removed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
thanks very much for your help!
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
@sbba1618 make sure that the locking mechanism is fully engaged. Sometimes it helps to push down a bit on the battery and see if that releases it. If that does not work, use a pair of hemostats or tweezers and try to pull it out with the release lever engaged.
Panasonic Lumix DMC-FH20 电池更换
这个答案有帮助吗?
得分 3
3条评论:
thanks. i can not get something around the battery to grasp it as it does not move after release of the locking gear
由完成的
@sbba1618 you may have to try to split the case and see if that releases the battery. It is possible that the safety latch has failed and stays engaged. This would of course involve a complete disassembly. Start with the posted guides
由完成的
thanks a lot it finally came out I'm so happy:)
由完成的
添加一条评论
If your battery is older it may have swollen slightly, generally that's because you need to stop using that battery it's time to get another, AND the tweezers can work better if you warm the camera up, like put it near your body if your out so that there is less tug hassle. The swollenness of the batteries demonstrate that they are aged and need replacing.
Update (05/12/25)
The swollen batteries are a danger to health. Lithium ION batteries can explode, so try to remove and get rid of them safely.
这个答案有帮助吗?
得分 1
1条评论:
Adhesive tape may work to grab and pull (depending on the issue). It worked for me on a similar camera.
由完成的
添加一条评论
添加你的答案
s.a. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 51
总计 4,013
