跳转到主内容
加入维修社区 - 创建账户
型号A1288,闪存容量:8、16及32GB
Charging Port Is Broken!
So on the bottom of any ipod (im pretty sure)there is what you would call a charging port.Thats basically where the usb cable goes. And well mine is kinda broken. Some of the little prongs(i guess you would call it)are either broken or bent. Due to that, my ipod cant be charged or updated and anything that includes the usb cable. Please help i dont know how to fix it! thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I've had no functional problems with this. Everything hooked up fine. I am running Windows 8.1 and have had no issues. It works like a charm.
https://www.amazon.com/Liztek-Universal-...
由完成的
添加一条评论
5个答案
已选择的解决方案
bella,that is the dock connector. You will have to replace it in order to get your iPod back to normal function. It is an interesting job to say the least. You have to remove the logic board and then desolder the connector. The dock connectors are available at multiple places like this Then you have to resolder the new one. here is a video that shows you how to do it. Good Luck.
这个答案有帮助吗?
得分 1
1条评论:
Just to add to what oldturkey said, I would recommend buying a fine tip for your soldering iron (not too fine) and definitely invest in some solder flux as well as thin solder wire. Great weekend project, good luck!
由完成的
添加一条评论
put the charger on the left side a bit lose and the other side normal
这个答案有帮助吗?
得分 0
添加一条评论
All you do is plug it into the charger.. Turn it off.. wait a hour or so.. should charge but you cant connect it to the computer that way, if it is dead plug it in, it will turn on automatically and then turn it off. Hope this helps x
这个答案有帮助吗?
得分 0
添加一条评论
Get a universal charger if the port is no longer working or damaged http://hpanswers.blogspot.com/2013/07/ge...
这个答案有帮助吗?
得分 0
1条评论:
Read the question :"Some of the little prongs(i guess you would call it)are either broken or bent." Your idea definitely does not work. Are you even remotely aware of the multifunction for the dock connector?
由完成的
添加一条评论
it want charge what do i do
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bella 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 37
总计 29,726
