跳转到主内容
加入维修社区 - 创建账户
Bose 3-2-1 家庭娱乐系统是 Bose 2.1 家庭影院系列中基于 DVD 的家庭媒体系统产品。Bose 3-2-1 家庭娱乐系统于 2001 年至 2006 年间销售,提供黑色和石墨色两种版本。
Bose AV 321 Subwoofer Not Working.
Bose Service centre says the parts are not available in India hence can’t repair. Buyers of bose are passionate about sound, difficult to just give up.
The Bass Module stopped working after a short circuit but the speakers are working.
Who would be able to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
5条评论
Hi Puneet Rawat
What had you tried?
What issues you are having now?
like able to turn on but no sound?
由完成的
Mine is well soldered but still no sound to the sub woofer except the smaller speakers only. What could be the problem? i have changed the TDA7396 twice now but no joy
由完成的
Hi Puneet,
did you manage to fix this? I’ve got exactly the same problem. I tested all resistors and capacitors up / from TDA7396 and they seem to be fine. I also replaced the TDA7396 as you did with no sucess. I’m really lost.
Felipe
由完成的
scusate il problema e di un chip siglato A3089G
sapete dove posso trovarlo?
由完成的
checco70t: How do you arrive to the conclussion that the problem is with that chip? Also, where is this chip located? it's not displayed in the electrical part list in the service manual
由完成的
添加一条评论
3个答案
最有帮助的答案
Puneet Rawat  this could be a Bass module issue on your Bose. Post some good pictures of the modules etc. with your question. That way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that.
Here is the schematic for the module and you can start checking components with a multimeter. Let us know what you find.
这个答案有帮助吗?
得分 3
添加一条评论
Have you checked the fuse?
From Bose Troubleshooting guide:
”AC mains power is connected by the line cord via jack J1. A slow acting fuse F1 is connected between J1 [D7] and the locking primary connector J3 (or J2 or J4) to protect against faults. A Metal Oxide Varistor (MOV) VR1 is placed after the fuse and across the line. It is used to protect against lightning strikes and other line transients. “
I did some research and it sounds like bad solder joints are common in this unit, So I would look for any cracked joints, cold solder, etc. while you are in there inspecting the fuse.
这个答案有帮助吗?
得分 1
2条评论:
Mov VR1 do you know wich one can i buy
由完成的
First you should use a meter to confirm that the part(s) is(are) bad. Start by re-flowing the solder to those parts. You can also short the fuse to see if it works, but I wouldn't recommend leaving it that way.. the fuse is there for safety of you and the device.
I found that part on tessco
https://www.tessco.com/product/suppresso...
由完成的
添加一条评论
ciao ragazzi io ho il problema uguale non va il sub il difetto e il chip A3089G sulla scheda madre del av3-2-1 potete darmi lo schema oppure sapete che sigla a questo chip? e dove poso reperirlo?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Puneet Rawat 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 35
总计 4,608
