跳转到主内容
加入维修社区 - 创建账户
型号 A1347。发布于 2012 年 10 月 23 日。搭载 Core i5 或 Core i7 处理器。配备 Apple Fusion Drive。
Adding second hard drive
My late 2012 Mac mini came with the hard drive installed in the upper bay (the one that is on the 'bottom' when the mini is upside down). I want to install an SSD drive in the other bay but can’t find the proper hard drive mounting pins. Where can I get these?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
T8 TORX HARD DRIVE SCREWS - Apple Mac Mini A1347 Mid 2010 2011 2012
Apple part #922-9584
http://www.powerbookmedic.com/parts/922-...
https://www.ebay.com/itm/T8-TORX-HARD-DR...
这个答案有帮助吗?
得分 6
4条评论:
Thanks very much. Just what I was looking for. :-)
由完成的 分享
@zarkov33 - Do you have all of the other needed parts? Here's the IFIXIT kit with the cable, rubber bushings and screws. It also has the needed tools. Mac mini Dual Drive Kit
由完成的 分享
Thanks Dan,
As I've explained earlier, I am trying to install an SSD in the lower, second drive, bay. This does not necessitate anything other than a SATA cable (which I have) and the 2 mounting pins (which I need). Everything else is unnecessary as it does not require removing the logic board. Thanks for your input. Everyone has been very helpful.
由完成的 分享
@zarkov33 - Just making sure ;-}
由完成的 分享
添加一条评论
I suggest you buy this dual drive kit for your Mac mini, it has those pins you need and it comes with the tools needed too.
为您的 Mac Mini 2012 晚期款 安装双硬盘模组
All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini.图片
产品
$29.99
这个答案有帮助吗?
得分 2
4条评论:
Thanks, but to add a second drive in the lower bay(closest to wifi shield) I don't need to remove the logic board. All I need are the 2 mounting pins.
由完成的 分享
BTW, I already have the proper SATA cable.
由完成的 分享
@zarkov33 The way I suggested is the best way to go thermal-wise. Your drive may not get the proper cooling where you want to put it so I am still suggesting you get that mounting kit so you can mount it correctly.
Plus, I have no idea where you are talking about putting this nor if it will work.
由完成的 分享
I plan on adding the drive to the second drive bay (lower bay). I know it will work because the mini is designed to hold 2 drives. I've done it before.
由完成的 分享
添加一条评论
添加你的答案
Tony 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 57
总计 1,136
