跳转到主内容
加入维修社区 - 创建账户
2016年1月发布,型号为 BDP-S3700
Why does the open/close button not work
I have disconnected both the audio and HDMI cable from my device.
After turning on the device, pressing the open/close button has not effect. The green power led is on.
I have tried resetting by holding on the open/close button, and the plugging in the power cord. This did not fix the problem.
Any suggestions or advice would be gratefully received.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@igreid wonder if it is in demo mode. While the player is turned on, press  ■ (stop) , RETURN, (pause), and then the SUBTITLE  button on the remote to disable it.
You can also try to open the case by inserting a paperclip in the hole of the drive
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the suggestion. This did not help.
This is the second unit I have had this issue with
Not sure what to do next.
由完成的
添加一条评论
添加你的答案
Ian Reid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 441
