跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
4G in iPhone 4S
Hello,
I’ve an iPhone 4S and I would know if is possible use 4G in this phone. I know that max capacity of iPhone 4S is 3G, but is possible with a valid and accurate way getting 4G?
Thank you in advance for reply.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Not possible, the best this phone can do is HSPA dual carrier at 14.4Mbps, anything above that is not possible, there is no hardware for it.
iPhone will display 14.4Mbps network of some carriers as 4G, but that is marketing only, not real 4G.
这个答案有帮助吗?
得分 5
添加一条评论
First of all, the Iphone SE is a phone that was made 5 years after the iphone 4s. Iphone 4s was just not made to support iphone 4s with the provider that you stated. 4g service was released in 2010 by 1 carrier- Sprint. It took a few years for other companies to catch on. Long answer short, the iphone 4s Was Not made to support 4g. Good Luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Patrizio Masini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 133
