跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
Crazy power issue? can you give me any advice!
Hey, Well I accidently dropped my iphone 4 into water :(.. The phone itself works fine if i keep using but as soon as its locked for over 1 min it wont come on unless I plug it into the wall and it will come straight on (it doesnt boot up its like it is on but not displaying anything until I plug it in)
I have tried ringing it when it is in the state of not responding and the other phone rings but the iPhone does nothing (no sound, no screen ect) However if I plug it in whilst its ringing it works instantly and i can see the call coming through and the sound starts to work..
Please please please help me or point me in the right direction.. I'd be extremely grateful for any help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
"However if I plug it in whilst its ringing it works instantly and i can see the call coming through and the sound starts to work.." sounds like a dock connector or Battery issue. The lithium Ion battery do not like moisture at all. Follow the advise given on this page. I would change the battery after that and see what you get. Let us know so we can continue to help you.
这个答案有帮助吗?
得分 3
2条评论:
Thanks for that i'll try the advice on that page but I think it will need a new battery
完成的
+ sounds right. a good clean and then reassess is always the best advice. you may have to clean a few times before reassemble. it's amazing what will suddenly start to work after a good clean..
完成的
添加一条评论
It was too long ago it dropped into water?
If not, you can try open it and let it in a dry place during some hours.
If it was too long ago, look for rusty contacts on the conectors.
这个答案有帮助吗?
得分 0
1条评论:
Wasn't took long ago but I think it has fully dried. Going to dissemble it tonight and see what i see.. Thanks!
完成的
添加一条评论
添加你的答案
cheelymeister 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 992
