跳转到主内容
加入维修社区 - 创建账户
袖珍型 GPS 接收器,配有 4.3 英寸触摸屏和蓝牙功能。
How do I replace the battery.
My Go720 is around 3yrs old and does not hold a charge anymore.
How do I take it apart to replace the battery?
There are only two small torqe screws on the back, no more apparent anywhere I can see.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
Thank you very much,I will keep you informed about how I go!
由完成的
you're welcome ;-)
由完成的
I have replaced the battery without any obvious problems, however my 720 will not open beyond the “connect to computer screen”. All files appear to be still in the unit, it just wont fire up. What have I done??
由完成的
edward, good job on replacing the battery. Have you tried to reset your 720. The reset on the bottom of the device forces a hard restart of the device, and does not otherwise change the contents. Also, of course, you checked and double checked your work to make sure that everything is connected the way it is supposed to.
由完成的
Hello again, Yes all was double checked so I’m confident it is back together properly. When I connect it to my computer it works perfectly with all memory functions, favourites and previous input and settings working perfectly, its when I disconnect from Tom Tom Home and try to use the unit it wont go beyond the start screen. Looking on the net it seems a common problem to some owners, it just seems like its missing a link to kick start the program. Obviously all the files required are in the hard drive but something happened when the battery was disconnected.
由完成的
添加一条评论
1个答案
最有帮助的答案
edward, here is a video on it and here are the written instructions. Hope you will take lots of pictures and create a guide for this ;-) Good Luck.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
edward 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 5,314
