跳转到主内容
The Kenmore Direct Drive is a washing machine by Kenmore.
20 个问题 查看全部
Timer clicking and only fill cycle works
Have a Kenmore 500 series.
A few days ago we started with another problem and the spin cycle would not work but everything else did. Replaced the clutch and rebuilt the transmission and the spin cycle worked for a few quick tests. Was excited. Then did a load of laundry and completely different problem now. The timer just makes a clicking sound on any position other than fill and the motor doesnt even try to start.
When I tilted the unit on its side was thinking something maybe got wet. Bad capacitor? Bad timer? I tried putting a cheap multimeter on the capacitor and it seemed ok, but not sure I was checking it right. Maybe something else out of place now? I did accidentally drop it a little hard on its side once.
Thanks a lot!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
So the problem was a small sock that made its way to the pump. I read other posts about that issue but was thinking the problem was related to the other work I had done. Plus did not hear any other posts relating it to the timer making the clicking.
So if none of the motor cycles are running and your timer is all you can hear clicking, then check your pump for a clog.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
这个答案有帮助吗?
得分 2
1条评论:
Thanks Mayer for that idea, lid switch was fine though. Ended up being a small sock stuck in the pump. Thanks again!
完成的
添加一条评论
添加你的答案
Ryan Coodey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 14
总计 2,209
